zooming too fast in autocad
Postby frigothermferrari » Tue May 15, 2012 6:06 am
Hi!
sometimes the movement (and specially the zoom) work WAY faster then they should.. i use the mouse normally, and then suddenly as soon as i zoom out the whole file becomes a little dot and i am FAR away from the drawing. why is this happening? and why is it happening only sometimes? it behaves almost as if the zoom/pivot point is far away, therfore zooming much faster...
thank you
best regards
Frigo
frigothermferrari
Re: zooming too fast in autocad
Postby UtaSH » Wed May 16, 2012 3:08 am
Hi frigothermferrari,
I assume you have AutoCAD 2012 or 2013? The navigation with the 3D mouse in AutoCAD 2010 or higher was implemented by Autodesk. You should address this issue with the AutoCAD support. It might be helpful for others if you post here when you find out what is wrong.
Postby frigothermferrari » Wed May 16, 2012 11:49 pm
Hi thanks for your answer!
i am having problems also with design review and the spacemouse.. contacting autodesk didnt help at all, they just dont answer.
spacemouse support in autocad and design review is crappy.. is there something you can do on your side?
regards
frigo
frigothermferrari
Who is online
