Experimental ZBrush support (Windows)
Discussion on the upcoming major revision of 3Dconnexion 3DxWare
Postby BeatKitano » Wed May 25, 2011 7:40 pm
Well if you fix that issue, yes zbrush experimental support is similar to a native support with dominant axis on (cause we can't interact on multiple axis at once due to the macro limitation). That's why I was making an heavy emphasis on that issue.
BeatKitano
Postby Nerd3D » Thu Jun 09, 2011 3:58 pm
If you can get the interaction of Wacom tablets sorted I could live with the dominant axis like behavior. Though I'd prefer multiple axis movement if possible.
Just seeing any movement towards zBrush support is very exciting.
Honestly if Mudbox gets native support there will be a copy of zBrush on the market cheap. I'll switch in a New York minute to which ever app makes it in to the the 21 century first.
Nerd3D
Postby BeatKitano » Fri Jun 10, 2011 5:32 am
Nerd3D wrote:If you can get the interaction of Wacom tablets sorted I could live with the dominant axis like behavior. Though I'd prefer multiple axis movement if possible.
Quoted for total agreement.
BeatKitano
Postby mattcscz » Thu Jun 16, 2011 2:31 pm
Hi guys im having trouble getting my space pilot pro to work with zbrush (4.0) im using 3dx version 10.0.10, im not sure if there any anything i have to enable before it works in z-brush? i have the right-click navigation enabled...
I get no response from the mouse in ZB at all :/
mattcscz
Postby ngomes » Thu Jun 16, 2011 11:45 pm
Hi mattcscz,
Are the demos working? Are you running the application as admin?
Postby mattcscz » Fri Jun 17, 2011 6:12 am
What do you mean by demos? also I've removed that administration thing from my OS so everything is admin :/ every other software works, max, maya ect
mattcscz
Postby ngomes » Fri Jun 17, 2011 7:02 am
mattcscz wrote:What do you mean by demos?
Start menu -> All Programs -> 3Dconnexion -> Demos.
But it's a moot point now: you have stated that it works fine with 3ds Max and Maya. That's a good enough data point.
Have you edited the "Zbrush" file in any way?
Postby mattcscz » Fri Jun 17, 2011 8:29 am
not that im aware of, it is however a educational version :/ I really hope this doesn't matter though as I can't stand zbrushes navigation!
mattcscz
Postby mattcscz » Fri Jun 17, 2011 8:36 am
After checking my program file >3d connexion/> I can't find any folder titled z brush, unlike Maya, Photoshop, sketch up ect.. maybe this is why >.< if i reinstall the driver (after uninstalling first) will it save my preferences? I had to rebind everything the other week and it took a good hour :/
mattcscz
Postby mattcscz » Fri Jun 17, 2011 8:40 am
or maybe someone could be kind enough to zip the zbrush directory up for me and attach :D?
mattcscz
Postby ngomes » Fri Jun 17, 2011 9:37 am
No folder for ZBrush. The support for the application is something completely different. (Did we say it is experimental?)
The driver is is emulating the normal mouse, using ZBrush's Right-Click Navigation feature.
Perhaps this is the issue? Can you use the right mouse button to move the view?
Postby mattcscz » Fri Jun 17, 2011 3:28 pm
mattcscz wrote: i have the right-click navigation enabled...
Im really not sure why this is happening :(
mattcscz
Postby ngomes » Sat Jun 18, 2011 5:25 am
Sorry, mattcscz. I managed to miss that...
Are you positive you are not running ZBrush as admin (you can check the "Security" of the ZBrush process properties in Process Explorer)?
Also, can you tell us what is the process name of ZBrush? We have "ZBRUSH.EXE" in the profile for ZBrush 4 and it may happen that the academic build has a different executable file name.
Postby mattcscz » Sat Jun 18, 2011 6:27 am
Im pretty sure all of my procceses i launch run as admin, but i ran as administrator anyways but still no luck... I decided to attach a screenshot, It confirms both administrator, ZBrush.exe and 3Dx running :/
http://imageshack.us/photo/my-images/43/zbrushss.jpg/
mattcscz
Postby ngomes » Sat Jun 18, 2011 12:08 pm
I cannot read anything on that image. I can only find a low resolution screenshot.
Anyway, your software should be not run as administrator. If you must run the application as admin, then the driver (3DxService.exe) must also be started as admin.
It does not matter if the login uses is an administrator: the problem is that selecting "run as administrator" will give elevated privileges to a program and, in doing so, prevents the driver from communicating with the application.
Try this: exit the driver (right-click on the systray icon and select "Exit 3DxService"), then go to C:\Program Files\3Dconnexion\3DxWinCore\ and right-click on the 3DxService.exe file and select "Run as administrator". Then try to see if you get some response in ZBrush.
If that works, you have ZBrush running as elevated. This is a problem.
Note: we do not recommend running any program (including the 3DxService driver) with elevated privileges as this may degrade the security of the operating system.
PreviousNext
Return to 3DxWare 10 Beta Forum
Who is online
Users browsing this forum: No registered users and 1 guest
cron
