3DxWare 10 for OS X Change History
Discussion on the upcoming major revision of 3Dconnexion 3DxWare
Postby flomotan » Wed Apr 06, 2011 4:54 pm
Change history for each beta release.
Beta 9 (v. 10.0.9, rev. 1419) of March 14, 2013:
  • New: Non-linear speed response to improve controllability with small cap displacements.
  • New: Add installer support for Gatekeeper (enabled by default in Apple OS X 10.8, Mountain Lion).
  • New: Added Virtual LCD panel for SpaceMouse Pro (activated with a long press on buttons "1" - "4").
  • New: Added Virtual Numpad panel (driver function).
  • Change: Remove 3DxQuickTime demo.
  • Fix: Fixed default settings to make Reader and Acrobat Pro work properly when both are installed.
  • Fix: [6224] System Preferences crash after entering a new macro.
  • Fix: [6173] New configuration has wrong mapping / default mapping differs (affected SketchUp plug-in).
  • Fix: Additional stability improvements to driver and plug-in software.
Beta 8 (v. 10.0.8)
  • Version 10.0.8 not publicly available.
Beta 7 (v. 10.0.7)
  • Version 10.0.7 available for internal testing only.
Beta 6 (v10.0.6) of July 20, 2012
  • New: Add support for Adobe Photoshop CS6.
  • Fix: Improve installation of the plug-in for Adobe Photoshop CS5.1 and CS5.5.
  • Fix: Stability improvements in plug-in for Adobe Photoshop.
  • Note: Update plug-in (Photoshop) to the same level as 3DxMacWare v. 1.7.2.
Beta 5 (v10.0.5) of June 19, 2012
  • New: Added support for SpaceMouse Pro.
  • Change: Update plug-ins to same level as 3DxMacWare v. 1.7.1.
  • Change: Added tooltips for ui elements.
  • Fix: [6067] Only button ID numbers <= 8 are received by applications.
  • Fix: Zbrush should now be detected correctly.
Beta 4 (v10.0.4) April, 7, 2011
  • Fixed Autodesk Maya plug-in installation issue
  • Updated default SpacePilot PRO setting for Google SketchUp. Added option for Roll and ISO view keys
  • Removed obsolete "3D Mouse" button commands to temporarily toggle rotations and translations
Beta 3 (v10.0.3)
  • Fixed "3Dconnexion Menu" toggle commands not working
Beta 2 (v10.0.1)
  • Fixed 3D Mouse Home applications Viewer and Trainer causing 3D mouse instability after being run.
Beta 1 (v10.0.0)
  • Initial beta release
Reason: Edit (moderator): [2013-Mar-14] Added change log for Beta 9.
flomotan
Beta 4
Postby BeCamilo » Thu Apr 07, 2011 10:17 am
I tried to installed it, but I still see the Beta 3.
I uninstalled the driver and tried again with no luck.
it is the beta 3, or at least that was what I downloaded a few minutes ago.
BeCamilo
Postby BeCamilo » Thu Apr 07, 2011 3:33 pm
I'm still unavailable to install the beta 4, even tough the name of the file is beta 4, i'm only installing the beta 3, I don't know if the problem is in my computer.
BeCamilo
Postby flomotan » Fri Apr 08, 2011 7:12 am
For 3DxWare 10 betas, we recommend uninstalling the old beta driver prior to installing the new one. To uninstall the driver, run /Applications/3Dconnexion/Uninstall 3Dconnexion Driver
flomotan
Postby mvanrijzewijk » Fri Apr 15, 2011 6:30 am
Downloaded and installed "3DxWare 10 Beta 4 (Mac OS X)" but indeed after installation and checking the Tools tab (or pane or how you call it) it shows Driver version 10.0.3
mvanrijzewijk
Postby mvanrijzewijk » Fri Apr 15, 2011 6:35 am
mvanrijzewijk wrote:Downloaded and installed "3DxWare 10 Beta 4 (Mac OS X)" but indeed after installation and checking the Tools tab (or pane or how you call it) it shows Driver version 10.0.3
To add to this: I didn't have a previous beta installed on my Mac, only the last official version 1.6.3
mvanrijzewijk
Postby flomotan » Fri Apr 15, 2011 8:21 am
Thanks for pointing out the version inconsistency. We have confirmed the version number was not incremented properly in Beta 4 and remained at 10.0.3. However, we've also confirmed that the contents of the beta are correct and indeed have all the changes that were meant to be part of Beta 4.
Sorry for this confusion.
flomotan
What about spacepilot
Postby Harsenik » Fri May 06, 2011 1:10 pm
there is gonna be some driver to make the spacepilot work on mac?!
thx
Harsenik
Postby ash0080 » Sat Jun 04, 2011 9:32 pm
Will Space Pilot be supported on OSX later or not?
ash0080
Postby Harsenik » Sun Jun 05, 2011 5:17 am
Im waiting an answer for this for over a year... no one seem to care about SP users on mac.... that piss me off BIG TIME...
Harsenik
Does anyone test the spacepilot on mac?
Postby nxym » Tue Jun 07, 2011 3:29 pm
I'am almost to buy the spacepilot pro. After a search i found that a beta release suppose to work spacepilot pro on Mac. I would like to know if anyone test it and if it is fully fuctionality as on pc's. What problems? etc. I want it for Maya and photoshop most of the time.
Pls help ...
nxym
SpacePilot support???
Postby gje73 » Mon Jul 04, 2011 8:31 pm
Well, the last beta release for OS X was back in April. This project seems to be stagnant. I would really like to know whether work is going to continue on Beta 10 sometime soon, in particular adding original SpacePilot support under OS X. The Windows support is good, but I would like to use my device with OS X as well.
Can someone in the know please update us on the status?
gje73
Re: SpacePilot support???
Postby ngomes » Tue Jul 05, 2011 2:03 am
Hi gje73
Work is on-going. We have a more stable release, so you will see less frequent updates.
I'm sorry but we have no plans to bring SpacePilot (1st generation) support to our 3DxWare 10 for Mac. This device was not officially supported on the Mac and was discontinued over a year ago.
Postby spam3d » Wed Jul 06, 2011 5:03 am
ngomes wrote:I'm sorry but we have no plans to bring SpacePilot (1st generation) support to our 3DxWare 10 for Mac. This device was not officially supported on the Mac and was discontinued over a year ago.
this would be very lousy for a growing number of people who now switch to Mac and love their SP. I´m a student of engineering and I´ve would even pay for the SP Support, but to buy a SP Pro only for Mac support would not happen, especially because of the ignorance of 3DConnex in this Chase.
To give an idea of compromise:
Coud you implement an unofficial Support for the KEY´s of the SP ? I don´t need the display, but it would be very sad to waste the existing Buttons on the SP. And the SP will be on my desk, with or without Mac support
spam3d
Postby ngomes » Wed Jul 06, 2011 5:32 am
Hi spam3d,
Have you tried connecting your SP on a Mac?
How would you like use your SP on the Mac? Are you considering using with Windows running in Paralells or Fusion, say?
Next
Return to 3DxWare 10 Beta Forum
Who is online
