3DxWare 10 Beta Feedback
Discussion on the upcoming major revision of 3Dconnexion 3DxWare
Postby BeatKitano » Thu Mar 31, 2011 10:29 am
Same functionality and same limitations as xpadder.
We can't have the space pilot pro movements without mouse cursor movements, making it almost useless as soon as you leave the viewport of any unsupported 3d app because yo ustart to grabe and move things in the ui. :/
The driver needs to lock the current cursor position before 3dx interaction and restore it every x ms. At least that's what I think, I'm taking zbrush for example you can't have panning without starting to zoom (with the zswitcher plugin).
BeatKitano
Postby jwick » Thu Mar 31, 2011 10:41 am
BeatKitano wrote:Same functionality and same limitations as xpadder.
Yup. We are looking into this. With 3DxWare 10, we have the ability to create very highly tuned solutions for specific applications. There does appear to be a class of applications that we can address together though. We have been experimenting with smarter cursor movement. Stay tuned.
It is not our intention to have the same limitations as anyone.
Postby BeatKitano » Thu Mar 31, 2011 11:32 am
I can't edit my first post so here's another remark. In firefox (and probably in other apps), you can cycle your tabs with ctrl+tab and ctrl+shift+tab.
But in the 3dconnection propertie tabs if you press tab as a keystroke, it acts like the normal tab, and switch to the next ui input: we can't assign tab as a keystroke.
Thanks for the feedback on smart cursor movment, I'm eager to see how it works.
BeatKitano
Menu Button Editable
Postby chaseacej » Thu Mar 31, 2011 11:37 am
The menu button needs to be editable. Especially on the SpaceNavigator where there is only 2 buttons. It is now basically limited to one button.
SpacePilot Pro
Windows XP SP2 x64
chaseacej
Postby jwick » Thu Mar 31, 2011 11:38 am
BeatKitano wrote:But in the 3dconnection propertie tabs if you press tab as a keystroke, it acts like the normal tab, and switch to the next ui input: we can't assign tab as a keystroke.
THAT'S the other place I need to look at. I knew there were two. The Macro Editor and the Advanced Motion tab.
Postby Phil999 » Thu Mar 31, 2011 12:53 pm
BeatKitano wrote:In firefox (and probably in other apps), you can cycle your tabs with ctrl+tab and ctrl+shift+tab.
hey thanks, I was always wondering what key command is needed for that, but was too lazy to investigate.
Yes, the Tab and the fixed menu button is something that has been discussed many times. I feel so free to vote for this to change in future versions as well. Thank you Jim for listening, I appreciate that.
Phil999
Postby BeatKitano » Thu Mar 31, 2011 1:09 pm
BeatKitano
Postby BeatKitano » Thu Mar 31, 2011 1:11 pm
Sorry for the unfortunate and useless quote post, it's a shame we can't edit our posts...
I wanted to say:
@jwick a simple "2b" should be quite easy to add ;) I did it manualy anyway.
The cursor thing appart the driver is almost perfect.
When that is fixed we can officially say that there is no "unsupported app" :)
BeatKitano
Postby jwick » Thu Mar 31, 2011 1:29 pm
BeatKitano wrote:@jwick a simple "2b" should be quite easy to add ;) I did it manualy anyway.
You are catching on. Getting to know the xml is very helpful.
Good JOB !!!
Postby zzz2496 » Thu Mar 31, 2011 1:33 pm
Finally, the day I dust-off my Spacepilot Pro arrived !!! Thank you soooo much, jwick (and all 3Dconnexion device driver developers) !!!
zzz2496
zzz2496
Postby Tehrasha » Thu Mar 31, 2011 3:26 pm
Good timing on the release. If I had heard about 24hrs later, I would have dismissed it as an April Fools joke.
Cant wait to get home and test out the new functionality.
Tehrasha
Postby NickDavy » Fri Apr 01, 2011 1:39 am
NickDavy wrote:As my Cadman is not listed am I right to assume that this will not work for me?
If so thats a right pain, the Cadman performs fine for my CAD work so I see little need to rush out and change it.
I guess that the deafening silence answers my question then. :cry:
NickDavy
Postby jwick » Fri Apr 01, 2011 5:43 am
NickDavy wrote:I guess that the deafening silence answers my question then. :cry:
3DxWare 10 only supports products in the current product line. The CadMan hasn't been supported in quite a long time.
problem with Bodypaint 3D
Postby yasu21net » Fri Apr 01, 2011 9:47 am
it doesn't work on BodyPaint 3D once its own profile is created. but it does work if you delete the profile, which means you can't change settings for BodyPaint at all.
Windows 7 sp1 x64
BodyPaint 3D R12 x64
yasu21net
Postby CPConsult » Fri Apr 01, 2011 10:30 am
If you ever try to get ISO certification, don't they have time line that you have to support your products? I wonder why they would do that? Maybe because it is the right thing to do!
CPConsult
PreviousNext
Return to 3DxWare 10 Beta Forum
Who is online
Users browsing this forum: No registered users and 4 guests
