jwick wrote:There was a bug in ProE a while back, in that it was always telling 3DxWare to display its GUI. They fixed that at some point. Do you see the same behavior with the non-beta versions of 3DxWare (the shipping version)?wavez wrote:Hi Jwick,
I think the new beta12 works well bu I have a little problem; I use my space navigator with an old pro-E wildfire 2 and everything works fine except that every time I start Pro-E it appears the window of "3Dconnexion Properties" and I have to confirm OK button; I read that I should manually install the file "protk.dat" and thinked that this would solve the issue, but unfortunately in 3Dconnexion drivers did not exist a folder for Wildfire2... may I use the WF3 instead of my version or it is better to continue this way, without install anything?
As always thanks for your valuable advice.
Hello, wave
I tried only with beta 12 because the space navigator I purchase last week from a shop has a 2009 CD driver: [3DxCDROM v. 3-7-18-0; 3DX-500160 CD,SW,3DX STD,RTL,07-2009] and so I download directly drivers from the website.
Is there a solution to the issue installing the "protk.dat" or do you think is better I will continue without installing no other plugin?..anyway the ProE parts movement and control are fluid and comfortable.
Thank you in advance for the answer
Ciao Wave
