I use the two buttons on the space mouse to control movement sensitivity, but roation sensitivity is draged with it and makes me spin uncontrolably when need high sensitivity or hardly rotate at all when is low. Any way I can and isolate sensitivity shortcut controls just for movement axis.
If this is no posible is there a way to apply automatic sensitivity when scaling into smaller or larger areas like the standard mouse.
Any help or suggestions would be grateful
space mouse manual sensitivity control with the two buttons
Re: space mouse manual sensitivity control with the two butt
Hi cesern,
you can control each axis separately in the Advanced Settings.
