SpaceExplorer stops working after reboot...
Questions and answers about 3Dconnexion devices on Windows
Postby pcushion141 » Wed Aug 03, 2011 4:01 am
Good Morning,
I am running SolidWorks 2010 SP4.0 on Windows 7 with a 3Dconnexion SpaceExplorer USB input device.
A few days ago the 3D mouse stopped working with SolidWorks. It works with Altium and PTC-Solid Designer. I have installed the updated software. I have uninstalled the drivers, and then reinstalled them. I have uninstalled SolidWorks and reinstalled... I can get it working, but when I reboot, it stops working on SW alone.
Has anyone seen this problem before?
Windows-7-64 bit.... 3Dconnexion SpaceExplorer USB ... SolidWorks 2012-SP5.0 ... AutoCAD-LT 2013... Altium 2010
pcushion141
Postby Fred » Wed Aug 03, 2011 8:14 am
Sounds like the add-in is getting unchecked.
Go to Tools
Add-ins
Verify 3Dcontrol is checked, also checked to launch at startup of Soildworks.
Fred
Postby pcushion141 » Wed Aug 03, 2011 8:23 am
All that has been considered and looked at... Right now I have fully uninstalled the drivers... Going to clean the registry out and reinstall from CD that came with package...
pcushion141
Postby Fred » Wed Aug 03, 2011 9:20 am
What OS are you running?
Win 7?
Is Solidworks installed to run as administrator?
You should be able to install the application without running as admin.
Otherwise you'll have to run our driver with the save priviledges, win 7 wont let the addin run.
Go to the startup folder right click on the start driver icon choose properties, compatibility at the bottom chose run as administrator
save
Reboot pc and see if the add-in loads and the device is recognized.
There is a feature in SW that in the past would uncheck the Solidworks addin. not sure where its located or why it would do it.
You can manually launch the addin by going to:
File
Open
Change file type to All files
Browse to:
C:\Program Files\3Dconnexion\3Dconnexion 3DxSoftware\3DxSolidWorks32
Choosse the TdxSW32.dll this will launch the addin.
Path will very depending on if your running 64 or 32 bit application and OS.
Fred
Postby pcushion141 » Wed Aug 03, 2011 10:52 am
Thanks Fred...
I will try this and get back to you.
Regards... Paul.
pcushion141
Postby pcushion141 » Wed Aug 03, 2011 11:54 am
Hi Fred,
So far so good but the real test will be in the morning.
I will update you then.
Regards,
Paul.
pcushion141
Postby pcushion141 » Thu Aug 04, 2011 3:39 am
Hi Fred,
I wanted to let you know that I had success this morning manually starting up SolidWorks and the driver for my SpaceExplorer.
To answer a couple of your questions....
Fred wrote:What OS are you running? Win 7? ... Yes, Win-7
Is Solidworks installed to run as administrator? ... Yes, Would that cause problems from the start?
save
Reboot pc and see if the add-in loads and the device is recognized. .... I did this and had to manually start the driver... Which is fine since it seems to be working for now.
If I changed SW back to run in regular mode compared to "Admin" and I changed the 3DxWare back to regular mode, do you think they might play better together?
Thank you for your help.
I greatly appreciate it.
Paul.
pcushion141
Postby Fred » Thu Aug 04, 2011 4:11 am
Yes, you can change both to run normally. The run as admin is a security feature in Win7, and Vista. When you install and run an application as administrator any add-ins that are installed will also need the same permissions.
:wink:
Fred
Postby pcushion141 » Thu Aug 04, 2011 4:14 am
Ahhh ... I see.
That has probably been my problem from the start.
I will get through the day and change them over and respond back.
Thanks again....
pcushion141
Postby pcushion141 » Thu Aug 04, 2011 6:18 am
It seems that was my problem all along...
SolidWorks had been set to run as administrator and the 3DxWare driver was set to run normally. So SW did not recognize or run it.
After setting both applications back to run normally, everything appears to be functioning as it should be.
Thank You very much for your help with this.
pcushion141
Re: SpaceExplorer stops working after reboot...
Postby lxs123 » Mon Oct 22, 2012 10:47 pm
The administrator fix worked for me!!!
lxs123
Return to Windows Discussion Forum
Who is online
Users browsing this forum: No registered users and 5 guests
