buttonaction in macro
lumi
Post by lumi »
Hi all,
I work with autodesk inventor 2018.
I would like to execute a command from Buttonaction (open component). (this command is available in 3dconnnection binding but not in shortcut of inventor).
this code doesn't work
<MacroEntry><ID>iprop + tab tab</ID><Sequence>
<ButtonAction Type="AppCommand"><ID>AppCommand_PresentationSelectLeafPartPriorityCmd</ID><Name>Priorité à la pièce</Name><AppCmdID>PresentationSelectLeafPartPriorityCmd</AppCmdID></ButtonAction></ButtonActions> (this line make problems)
<Pause>300</Pause>
<KeyPress>22</KeyPress>
<KeyRelease>22</KeyRelease>
<Pause>300</Pause>
<KeyPress>E0</KeyPress>
<KeyPress>2B</KeyPress>
<KeyRelease>2B</KeyRelease>
<KeyRelease>E0</KeyRelease>
<Pause>100</Pause>
</Sequence></MacroEntry>
Thank you for your help.
Lumi
Re: buttonaction in macro
That XML syntax isn't right.
It sounds like you want to assign a keyboard macro to a button. That can be recorded in the GUI.
If you find you need the pauses, those can be inserted as you've done, or recorded by the GUI with a little beforehand magic.
The XML says this is an AppCommand, which is different than a keyboard macro.
