Questions and answers about 3Dconnexion devices on Windows
Postby GTWillemsen » Thu Sep 24, 2009 5:09 am
The First post of this thread states how to use this driver: click here
There is additional info in this thread, but since it's a lot of pages,.. succes with that :D
GTWillemsen
Postby Anumunrama » Thu Sep 24, 2009 7:17 am
if i download the files from omniflux teher is a driver and a modified .inf file ... but ... what should i do with that inf file ?
there is my issue
Anumunrama
sry for doppelpost
Postby Anumunrama » Thu Sep 24, 2009 7:27 am
if i TRY to insatll the driver windows says nothing but after the installation windows says the driver is coruppted or away but NOT unsignt (i mean an error or so)
thats why i need an new installation guide because the old one didn´t work ...
(errorcode 39)
Anumunrama
Postby GTWillemsen » Thu Sep 24, 2009 7:38 am
Try to sign in as admin and right click and alter the properties, execute as administrator (and/or) you might want to use the compatibility mode.
It depends on your OS (Vista/Xp/7/64/32) if you can use the drivers.
But if you follow the steps from the first post, it should work (probably).
You have to go into your device overview and select the correct HID corresponding with your 3Dmouse, then select the other driver.
If the driver isn't supported, you can either choose to set UAC off, or find a software package which circumvents these unsigned driver issues.
There are some packages for unsinged drivers mentioned on this thread, at least I think so.
Else: a search engine is your friend!
GTWillemsen
Postby Anumunrama » Thu Sep 24, 2009 7:48 am
my pc install the driver but after that windows says
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39).
i selected the right device and my windows dosn´t block unsignt drivers ... (in an older post i sayd how i do that)
i copid the RBC9-SpaceNav.inf and the RBC9-SpaceNav.sys files in
c/windows/system32/drivers /
and c/windows/system32/
but it dosn´t work !!!
Anumunrama
Postby GTWillemsen » Thu Sep 24, 2009 7:58 am
Didn't you use the 64bit version?
Anumunrama wrote:I hope someone will write an insallation guide fpr x64 vista
GTWillemsen
Postby Anumunrama » Thu Sep 24, 2009 3:55 pm
yes !
RBC9 Driver - TEST x64 build.zip 2009-01-14
from http://www.omniflux.com/devel/
but it dosn´t work
Anumunrama
Postby pggirvin » Thu Sep 24, 2009 7:56 pm
Anumunrama,
I have the same setup, so I am interested if you can get it to work.
I'm a little scared to wreck my system.
Are you pressing F8 when you reboot to allow the unsigned drivers to load?
Should the 64 bit drivers really be placed in the system32/drivers directory? That seems odd, but I am a newbie at this.
I don't mind buying xpadder, but I want to know that I won't run into an unsolvable problem first!
Thanks GTWillemsen for all your posts. You are kind to reply all the time.
thanks.
Patrick Girvin
pggirvin
Postby brandon9271 » Thu Sep 24, 2009 11:49 pm
I just installed RCB9 and it tells me "spacePilot not found" :( not sure why it does this but all my other apps are working fine. The only thing I can guess is that its because my SpacePilot is brand HP.. :?: Was really looking forward to playing some RTS with this thing.. :(
brandon9271
Postby Anumunrama » Fri Sep 25, 2009 2:53 am
for unsignt drivers i use this:
with this little code i forced vista to load unsigned drivers
bcdedit /set loadoptions DDISABLE_INTEGRITY_CHECKS
write this into the CMD line (with admin rights)
after that your pc need a reboot
[/code]
Anumunrama
Postby pggirvin » Fri Sep 25, 2009 6:23 am
Anumunrama
OK, I've read the whole stupid (yes, not stupid, but verrry looong) thread.
I think you are supposed to copy the .sys file to c:\windows\system32\drivers and the .inf file to c:\windows\inf *not* what you listed in your post above.
Maybe that's your problem.
Patrick Girvin
pggirvin
Access via DirectInput
Postby kabesc » Fri Sep 25, 2009 6:59 am
Hello to all,
I have read most parts of this thread, since I also want to use my Space Navigator to work as a joystick and/or mouse. I am using Vista x64 - seems to be the reason, why the solution provided and discussed here poses some problems.
Recently I found out, that one can access the Space Navigator (and possibly all of the other 3d mices?!) via DirectInput. So, I am wondering if it wouldn't be easier to just write a small app, that continuously reads the axes and buttons data and transforms it to mouse movements/mouse clicks (by Windows API calls)?!
I guess, someone else tried this before - so I would be happy if I get some response, why this would work/not work.
Regard,
Karl
kabesc
Postby Anumunrama » Mon Sep 28, 2009 8:11 am
thabks pggirvin for your try to help me
i copied the inf sys and exe files EVERYWERE !!! in teh inf ordner the driver ordner the driverbackup ordner but nothing work -.-
thts why i need help .... it still would´t wok :(
Anumunrama
Postby GTWillemsen » Tue Sep 29, 2009 3:01 am
brandon9271 wrote:I just installed RCB9 and it tells me "spacePilot not found" :( not sure why it does this but all my other apps are working fine. The only thing I can guess is that its because my SpacePilot is brand HP.. :?: Was really looking forward to playing some RTS with this thing.. :(
SpacePilot isn't supported, due to a bug. But the developer never got around that bug....
So same problem here..
kabesc wrote:Hello to all,
Regard,
Karl
You make it sound easy..
Like the logitech G-keys or such? Well if it could work...
GTWillemsen
Postby maveric_606 » Wed Sep 30, 2009 5:42 am
Yes, I tried it. But I have problem still...
When i click on "Properties" Driver status is:
Windows cannot verify the digital signature for the drivers required for this device. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source. (Code 52)
I don't know, what is wrong... I proceed along procedure on first page. Exactly.
maveric_606
PreviousNext
Return to Windows Discussion Forum
Who is online
Users browsing this forum: No registered users and 3 guests
