When 3D Connexion released the new 3DxWare 10 drivers in 2013 it became impossible for me to work on large models.
The movement of the mouse was extremely jittery, too fast, not able to focus when compared to the old drivers.
I've been using the old drivers ever since and limited to sketchup 2013 but I'm running out of time to find a fix.
Below are two short 1 min videos of the new and old drivers showing how they perform in a 3d model that is small in scale and then becomes large in scale. There is a huge difference.
New "3DxWare 10" Drivers:
https://www.youtube.com/watch?v=qsXH0mNVnak
Old "3dx Software" Drivers:
https://www.youtube.com/watch?v=fCQxeKBzZ84
Is there any solution to this?
Some notes:
- At the time the new driver was released I scoured the forums but found no posts highlighting the issue and wonder if it relates to the settings I use. They are: Axis_X Reversed, Axis_Z Reversed, Axis_Y NOT Reversed, Axis_Rx Reversed, Axis_Ry Reversed, Axis_Rz Reversed. Basically the original settings with all axis reversed and zoom direction push in/pull out on device
- I have tried both drivers on at least 5 different PCs, Operating Systems, Versions of sketchup, Versions of the driver itself. All have identical results to the video.
- In the videos above I used the exact same AppData\Roaming\3Dconnexion\3DxWare\Cfg\SketchUp.xml file
- I used the 3DxWare 10.2.9 driver in one video and the 3dx Software 3.17.8 driver in the other.
- I've tried adjusting every speed setting and even Deadband settings in many different combinations but it does not help
