Second life spacepilot pro config
Questions and answers about the SpaceNavigator 3D Mouse on Mac OS X
Postby vedus » Wed Sep 21, 2011 1:09 am
hello.i am trying to config my spacepilot pro for the SL.my problems is,all axis is working but i can reserve them when i go in 3dxware and change the axis nothing changed.i try to put a shortcut but still i can get anything.on the game is no working the zoom in-out i try with shortcut but still is no working..when i export the config to see it i get this
<xml>
<DOCTYPE>
<plist>
<dict>
   <key>macros</key>
   <array>
   <key>settings</key>
   <array>
      <dict>
         <key>application</key>
         <string>Second Life Viewer 2</string>
         <key>bundleid</key>
         <string>com.secondlife.indra.viewer</string>
         <key>dominant</key>
         <false>
         <key>enabled</key>
         <true>
         <key>factory</key>
         <false>
         <key>location</key>
         <integer>0</integer>
         <key>mappings</key>
         <dict>
            <key>00</key>
            <dict>
               <key>cmd</key>
               <integer>2</integer>
               <key>delay</key>
               <key>hash</key>
               <key>mod</key>
               <key>move</key>
               <false>
               <key>param</key>
               <key>repeat</key>
               <key>speed</key>
               <integer>150</integer>
               <key>thresh</key>
               <integer>30</integer>
            </dict>
            <key>01</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
               <integer>9</integer>
               <key>speed</key>
               <key>thresh</key>
            </dict>
            <key>02</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
               <key>speed</key>
               <key>thresh</key>
            </dict>
            <key>03</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
               <key>speed</key>
               <key>thresh</key>
            </dict>
            <key>04</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
               <integer>12</integer>
               <key>speed</key>
               <key>thresh</key>
            </dict>
            <key>05</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
               <integer>5</integer>
               <key>speed</key>
               <key>thresh</key>
            </dict>
            <key>06</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
               <key>speed</key>
               <key>thresh</key>
            </dict>
            <key>07</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
               <integer>3</integer>
               <key>speed</key>
               <key>thresh</key>
            </dict>
            <key>08</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
               <integer>8</integer>
               <key>speed</key>
               <key>thresh</key>
            </dict>
            <key>09</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
               <key>speed</key>
               <key>thresh</key>
            </dict>
            <key>10</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
               <integer>6</integer>
               <key>speed</key>
               <key>thresh</key>
            </dict>
            <key>11</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
               <integer>11</integer>
               <key>speed</key>
               <key>thresh</key>
            </dict>
            <key>14</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
            </dict>
            <key>15</key>
            <dict>
               <key>cmd</key>
            </dict>
            <key>16</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
            </dict>
            <key>17</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
            </dict>
            <key>18</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
            </dict>
            <key>19</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
            </dict>
            <key>20</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
            </dict>
            <key>21</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
            </dict>
            <key>22</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
            </dict>
            <key>23</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
            </dict>
            <key>24</key>
            <dict>
               <key>cmd</key>
               <integer>20</integer>
               <key>delay</key>
               <integer>1</integer>
               <key>mod</key>
               <integer>256</integer>
               <key>param</key>
            </dict>
            <key>25</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
            </dict>
            <key>26</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
            </dict>
            <key>27</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
            </dict>
            <key>28</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
            </dict>
            <key>29</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
            </dict>
            <key>30</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
            </dict>
            <key>31</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
            </dict>
            <key>32</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
            </dict>
            <key>33</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
            </dict>
            <key>34</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
            </dict>
            <key>35</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
            </dict>
            <key>36</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
               <integer>53</integer>
            </dict>
            <key>37</key>
            <dict>
               <key>cmd</key>
               <key>mod</key>
               <integer>512</integer>
               <key>param</key>
               <integer>255</integer>
            </dict>
            <key>38</key>
            <dict>
               <key>cmd</key>
               <key>mod</key>
               <key>param</key>
            </dict>
            <key>39</key>
            <dict>
               <key>cmd</key>
               <key>mod</key>
               <integer>4096</integer>
               <key>param</key>
            </dict>
            <key>40</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
               <integer>26</integer>
            </dict>
            <key>41</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
               <integer>25</integer>
            </dict>
            <key>42</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
               <integer>27</integer>
            </dict>
            <key>43</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
               <integer>28</integer>
            </dict>
            <key>44</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
               <integer>29</integer>
            </dict>
            <key>45</key>
            <dict>
               <key>cmd</key>
               <key>param</key>
            </dict>
         </dict>
         <key>name</key>
         <key>pid</key>
         <key>rotations</key>
         <integer>7</integer>
         <key>signature</key>
         <integer>1061109567</integer>
         <key>speed</key>
         <integer>198</integer>
         <key>translations</key>
      </dict>
   </array>
   <key>version</key>
   <string>10.0.3</string>
</dict>
</plist>
here is the photo from game settings Image
and here is the 3dxware settings Image
ant help on this ?
vedus
Return to Mac OS X Discussion Forum
Who is online
Users browsing this forum: No registered users and 1 guest
