Blender: problem with rotation only
Questions and answers about 3Dconnexion devices on UNIX/Linux
Postby radionator » Fri Aug 14, 2009 3:09 pm
I successfully installed a Spaceball 5000 on Ubuntu 8.10 using the driver from 3dconnexion (3dxware-linux-v1-4-3.i386).
I also installed the plugin for Blender: 3DxNdofBlender.plug (v0.1 - 31 July 2007)
The xcube works fine in all 6 directions. All motions are OK and the right direction.
Even in Blender (2.46) translation works in all 3 directions.
There is only a problem with rotation:
X: OK
Y: rotates reverse
Z: does not work
I have checked this by switching all axis off and then switching each axis on separately.
Reverse Y and Z translation did not work.
Has anyone else experienced this (and solved)?
Is there a setting in Blender to adjust this?
Thanks in advance for your support
Rai
radionator
Postby Tuxie » Tue Feb 16, 2010 6:48 am
I have this problem too ! (vertical rotation)
Xcube works correctly but Blender, no. The Blender plugins is very old, it can be reason ???
Please, that to make ? I have a half of SN.
Tuxie
Return to UNIX and Linux Discussion Forum
Who is online
