- Code: Select all
1 matt@mattWorkstation 3dconnexion$ /etc/3DxWare/daemon/3dxsrv -d usb -debug -userName matt
[2012-07-27 22:19:05] uddev.c, 783: UdDevInit() 0xe1f010
[2012-07-27 22:19:05] 3dxsrv.c,806: displayname = :0
[2012-07-27 22:19:05] auth.c :: authGetUser(), FOUND: user home = "/home/matt"
[2012-07-27 22:19:05] 3dxsrv.c :: startupCommandLine(), authGetUser(), user=matt
Error: Access Error! To get access to /dev/bus/usb/008/005 you have to be user: root!
Error: Access Error! To get access to /dev/bus/usb/008/005 you have to be member of group: root!
[2012-07-27 22:19:05] Error: Could not open USB port or no supported device found! Exiting!
1 matt@mattWorkstation 3dconnexion$ sudo /etc/3DxWare/daemon/3dxsrv -d usb -debug -userName matt
[2012-07-27 22:19:20] uddev.c, 783: UdDevInit() 0xcc5010
[2012-07-27 22:19:20] 3dxsrv.c,806: displayname = :0
[2012-07-27 22:19:20] auth.c :: authGetUser(), FOUND: user home = "/home/matt"
[2012-07-27 22:19:20] 3dxsrv.c :: startupCommandLine(), authGetUser(), user=matt
[2012-07-27 22:19:20] UdDev: Opening USB device on USB port /dev/bus/usb/008/005
[2012-07-27 22:19:20] UdDev: Opening SpacePilot PRO on USB port /dev/bus/usb/008/005
Error: Failed to submit URB! (No such process)
[2012-07-27 22:19:20] spilotpro_usb.c :: UdDevRezero(): Rezeroing the device
[2012-07-27 22:19:20] spilotpro_usb.c :: UdDevSetDeadband(): Setting deadband to 26
[2012-07-27 22:19:20] 3dxsrv.c,831: UdDevOpen() was successful [SpacePilot PRO]
[2012-07-27 22:19:20] 3dxsrv.c,842: authorizeWithX11() was successful
[2012-07-27 22:19:20] 3dxsrv.c :: startupCommandLine(), XOpenDisplay called with display name=:0, display = cc8510
[2012-07-27 22:19:20] 3dxsrv.c :: startupCommandLine(), SUCCESS!
3DxWareUNIX = V1.6.0
Device = SpacePilot PRO
Firmware = V4.11
[2012-07-27 22:19:20] Home directory: /home/matt
[2012-07-27 22:19:20] UiSb: Directory "/etc/3DxWare" opened for configs.
[2012-07-27 22:19:20] UiSb: Directory "/home/matt/.3dxcfg" not found
udusb_linux.c :: UdUSBStartRead(), Error submitting URB: No such process 3 -1
^C udusb_linux.c :: UdUSBStopRead(2), ret = -1, Interrupted system call == 4, i=0, j=0
^Z
Does that give you any sort of clue as to what might be wrong?
