Weird behavior of X-Axis in Demo App
Post questions, comments and feedback to our 3Dconnexion UNIX/Linux Development Team.
Postby gertius » Thu Jan 24, 2008 9:59 am
first of all thanks for all your other tips! I feel I
gertius
Postby crobl » Fri Jan 25, 2008 8:49 am
Hi gertius,
keep in mind that our devices have a fairly sensitive sensor! This means, if move the cap of the device not precisely in the direction of this single axis, other axes may also deliver some values.
For example if you put your SpacePilot a bit askew on your desk and then push the cap exactly away from you, the Cube (for example) might not only become smaller, but also be moved a bit aside.
Anyway, if you have default sensitivity set in the driver the values you're reporting are fairly small and may be a case for warranty replacement of the device.
I've sent you a mail regarding this.
Regards,
Christian Robl
crobl
Return to Developer's Forum for UNIX/Linux
Who is online
cron
