Space Navigator for Notebooks working in a background app
Postby superbigio » Mon May 16, 2011 7:48 am
Hi there,
I recently bought a Space Navigator for Notebooks and I want to integrate its functionality in an application.
The idea is to get something that supports multiple devices as well. I see that is possible with the Max OS X API.
I am writing some driver code to capture the data sent by the SN and I run into a problem.
When the app in question is not the frontmost app I stop receiving data from the SN.
If I initialize the device with the following code:
clientID = RegisterConnexionClient('max2', NULL, kConnexionClientModeTakeOver, kConnexionMaskAll);
I receive data normally, but only if the app is frontmost.
This is the code that - according to the docs - should allow me to receive data no matter if the app is frontmost or in the background:
clientID = RegisterConnexionClient(kConnexionClientWildcard, NULL, kConnexionClientModeTakeOver, kConnexionMaskAll);
However, in this case I don't receive anything at all.
What am I doing wrong ?
Thanks.
- Luigi Castelli
superbigio
Postby superbigio » Mon May 16, 2011 7:49 am
ok, nevermind... my bad.
I was doing something silly and figured out the mistake.
Now, just to clarify:
if I register my client as follows:
then I only receive events when my application ('max2') is in focus,
whereas, if I use:
then I receive events whether we are in focus or not. Correct ?
In this mode why would I need a client ID ? Can I safely disregard it ?
Thanks.
- Luigi Castelli
superbigio
Postby flomotan » Wed May 18, 2011 5:21 pm
The returned clientID is needed to properly close down the connection and release any callback handlers you've installed. You'd need it in the call to UnregisterConnexionClient(fConnexionClientID);
Also be sure to call CleanupConnexionHandlers(); after you unregister.
flomotan
Postby superbigio » Thu May 19, 2011 1:30 pm
That's right, of course...
Thanks for your help.
- Luigi
superbigio
Return to Developer's Forum for Mac OS X
Who is online
Users browsing this forum: No registered users and 1 guest
