C# Process and CATIA
Postby Jens » Wed Feb 29, 2012 3:06 am
Hello all,
I have the following Propblem.
If I Start CATIA via a Process from a C# User Form, the Space Pilot did not
work. Any suggestions
Kind regards.
Jens
Jens
Postby ngomes » Wed Feb 29, 2012 8:14 am
Hi Jens,
Not sure we follow you.
Are you spawning a CNEXT.exe from an WinForms C# program? And when you do, the 3D mouse will not work in CATIA?
How are you configuring the environement that CNEXT.exe runs in? A common pitfall is to use the ADT_ODT_IN environment variable to speed up application start. That will cause the 3D mouse (and other input devices)support to be disabled. For more information, refer to this FAQ article.
Hi NGomes
Postby Jens » Thu Mar 01, 2012 3:40 am
Ok, I will try to explain the Problem.
I have a C# Windows Application with a Form.
On the Form there is a Button. In the Button Click Event I do the Following
            string CATDLLPath = @"C:\Program Files\Dassault Systemes\B19_SP09\win_b64\code\bin";
            string EnvironmentName = @"Catia_B19_SP09_HF0";
            string ApplicationPath = @"C:\Users\Jens.Schimmelpfennig\AppData\Roaming\Test";
            bool AdminMode = false;
            ProcessStartInfo psi = new ProcessStartInfo("\"" + CATDLLPath + "\\CATStart.exe" + "\"");
            if (!AdminMode)
                psi.Arguments = " -run \"CNEXT.exe\" -env " + "\"" + EnvironmentName + "\"" + " -direnv " + "\"" + ApplicationPath + "\"" + " -nowindow";
            else
                psi.Arguments = " -run \"CNEXT.exe -admin\" -env " + "\"" + EnvironmentName + "\"" + " -direnv " + "\"" + ApplicationPath + "\"" + " -nowindow";
            Debug.WriteLine(psi.FileName + " " + psi.Arguments);
            IntPtr oCatiaHwnd= IntPtr.Zero;
            bool bFound = false;
            psi.UseShellExecute = false;
            psi.RedirectStandardOutput = false;
            psi.RedirectStandardError = true;
            //Prozess starten und auf dessen Ende warten
            //using (Process process = new Process())
            Process process = new Process();
                process.EnableRaisingEvents = true;
                process.StartInfo = psi;
                process.Start();
                Application.DoEvents();
                Process[] Ps = Process.GetProcesses();
                int L = Ps.Length;
                int timeout = 5000;
                process.WaitForExit(timeout);
In the Environment File there is no Entry ADT_ODT_IN.
Hope this explains my problem better.
Kind regards
Jens
Jens
Postby ngomes » Thu Mar 01, 2012 5:25 am
Do you see an empty CATProduct after launching CNEXT?
Try enabling your application process in the firewall. CNEXT needs to access to the loopback network device to funciton properly. By launching CNEXT from your application, you may be restricting the spawn process.
Postby Jens » Thu Mar 01, 2012 11:36 pm
Yes I See an Empty CATProduct when I Start CATIA from my Application.
I have Enabled my Application in thw Windows Firewall, but the problem is still the same.
Kind regards
Jens
Jens
Postby ngomes » Fri Mar 02, 2012 5:05 am
I'm running short of ideas... Have you checked if CATIA works as expect if you start it normally?
Postby Jens » Fri Mar 02, 2012 5:53 am
After some investigations, I found the Problem.
My Application needs for some Task Admin rights.
So I add a Manifest to my Application
requestedExecutionLevel  level="requireAdministrator" uiAccess="false"
this is the Problem. When I Change the Line above to the following
all works fine !
requestedExecutionLevel  level="asInvoker" uiAccess="false"
btw. CATIA works fine if I start CATIA with a Desktop Short cut.
Any Solutions ?
Kind regards.
Jens[/code]
Jens
Return to Developer's Forum for Windows
Who is online
Users browsing this forum: No registered users and 3 guests
cron
